WTB: Mortal Kombat I wiring harness
Is there any reason a standard jamma harness wouldn't work?
Did mk1 use a kick harness like 2 for the extra buttons?
Im not sure, I was told that I needed a dedicated MK harness for this. I am also looking for the power cable that connect the sound board with the game board
MK is just standard JAMMA with a kick harness for low punch and low block for each player so yes any old JAMMA harness *could* be used. If it's going into a dedicated MK cabinet it would be helpful to have one that was used in one before because it should (assuming it's not hacked) match up with any molex connectors Midway used in wiring it originally and not be missing any wires.
Bob Roberts sells them.
http://therealbobroberts.net/plus.html
One thing to keep in mind with MK1....depending on the board set you have, the kick harness will be different. It's like bulldawg said about your MK1 pcb being a "T-Unit" version or not. If your PCB is the T-Unit version you'd use the same kick harness as MK2-MK4, but if you have one of the earlier versions of MK1 (I believe called the Y-Unit) you'd use a slightly different harness. I think the majority of MK1 boards were the Y-Unit version and the T-Unit boards came out late in the production run so they aren't as common.
Exactly, most dedicated cabs I think used y-unit boards and the kits were t-unit. But the only difference is the kick harness. Like stated above any jamma harness should work.
