WTB: Mortal Kombat 3 control panel or run-button drilled MK2
K3V
Corfu, New York
Got a UMK3 board recently but don't want to put a hole in my very nice MK2 control panel for the run button. If you've got an MK2 control panel that's drilled or a UMK3 panel, drop me a PM! I want it.
Thanks.
Thanks! I actually remembered yours and tried to find it but couldn't when I made this thread. If you find a cache of them somewhere keep me in mind :D
Just drill your mk2. I was in the same boat and got an UMK cp to put in my mk2 cab. With the stock artwork it looks out of place. I ended up biting the bullet and drilling my mk2 cp. I am glad it did it too. If you have a drill press it makes it really easy. Use a bimetal drill bit as there is metal in the mk2 cp.
Well, IF you drill your MK2, if you don't use a bit meant for steel, the heat from the friction of the wrong bit will warp your panel around the hole AND mess up your overlay. Trust me on that :(
If you have the time/ability, I'd get a piece of 1/8" sheetmetal cut and use it to make a whole new CP, order a new CPO, and install it over your existing wood CP. I can't imagine it would cost any more than buying a CP complete with CPO that's already drilled from someone here.
Just my two cents.
