Anyone have a monitor for a dedicated Golden Tee 2005 cab, I think it is a 27" med rez monitor. I am also looking for a board set and would prefer 2004 or newer. Thanks.
I think the board you are refering to I missed out on. I am however buying his project cab and that is why I am looking for a monitor and board. Thanks for looking out though.
Dedicated Golden Tee 2005's had a 25" monitor originally. It can be either standard or medium-res, and you change a dip switch on the board to match the monitor. This is good news because med-res monitors are harder to find and more expensive.
There was a kit to upgrade these to the 27" tri-res monitors. They have you drill new mounting holes for the monitor supports. if your sides don't have an extra hole near the bolts showing the supports were moved, then your cab needs a 25" monitor....
Go with a STD res monitor. I spent BIG money to upgrade to a med res, and you can't tell the difference. Really, you can't. Maybe a true arcade expert could tell, but side by side, 99% of the people won't notice if it's std or med res.
Great info everyone, thanks. When I pick up the cab on Sunday I will check and see if it has the new mounts. If it doesn't I might just go with the 25" std res.
