WTB: Missile Command Transformer or Power Brick
Died?
How did it die?
Do you need a repair or did a shark hit it with a laser and turn it into slag?
I have spare Atari power bricks, but they are heavy to ship. If you can be more specific maybe we can just ship the parts needed.
No Sharks with lasers or molten lava.... Is failed a better term. The transformer is no longer putting out the 36v AC to the AR board. It is Atari part #A006886-01. Didn't think transformers were repairable? I'm sure shipping for the whole thing would be pricey since it ways a ton but would it be close to 1 Million dollars(holds pinky to lips)..
I have a brick from my asteroids parting, it works well with a new big blue. You can check, but I think they are interchangeable.
No, they aren't. Missile command has several different power bricks with the uprights and minis and cocktails with different numbers. I have one but it is in a project cabinet right now. I will dig thru my spare bricks and see if I have a spare missle command.
A Missile Command power brick / transformer won't output 36VAC even if it's working.
You should see the following voltages off the 12 pin molex on the power brick:
Pins 1&2 = 10.3VDC
Pins 4&6 = 25VAC
Pins 4&5 = 12.5VAC
Pins 11&12 = 6.3VAC
