Wtb- missile command cabaret parts
GeorgeGlass
Donor 2016
Hamilton, ON, Canada
I'm new to this restoration part and luckily got a missile command cabaret.
the cab is great but it has nothing in it. I'm looking for control panel - pcb board/ marquee. Anyone have any of these parts out there?
As a fellow MC Cabaret restorer, I wish you the best of luck. Does yours have the metal trim cap at the top, wire harness and power block? PCBs you can find, there's a gent on the board that sells bulletproofed ones with upgraded sockets. Marquee is also doable, they pop up on occasion. The control panel might be the hard part. Best of luck on the restore, document it on the restore board!
FYI
There are two MC cabaret marquees on eBay right now.
Scott C.
Got the marquee off eBay
The metal top clip is intact have coin mechs and wiring for marquee that's about it. I'm in no rush to complete this project I will take it piece by piece
Sent from my brain using a carrier pigeon.
I have the three black non-lit cone buttons, with short cones, and the small harness that goes with them.
The harness says it's part number A036095-01, which the manual says is for the cocktail. The cabaret is a different part number, but I don't know how different it is, or if you could mod this one to work. The buttons are the same though, and you can have the harness for free if you want it.
