modessitt
Needed for the following tubes:
K4915
K5515
K7600 (or any other med-res K7000 model)
Please understand that a yoke with the same ohm-readings will NOT work if it's not specifically for the med-res monitor. If it was that easy, I wouldn't need any.
I'd be open to other med-res models also.
And if you have some yokes from less-common monitors of any resolution - like Hantarex, Mitsubishi, Neotec, Kortek, Sharp Image, etc - let me know what you got and what you want for it.
I need these help with the growing number of monitor repairs I'm being asked to do. I can usually fix them all (provided parts are available), but I can't test them properly without a yoke and tube. I have most tubes, but not most yokes.
Thanks...
K4915
K5515
Thanks...
