WTB: Matsushita TM-202G Chassis
philt80
Virginia
Have a beautiful burn-free matsushita monitor with a nonworking chassis...
Anyone have a working TM-202 chassis for one of these?
Thanks in advance,
Phil
Thanks for that!
The vertical output transistors in mine were bad causing vertical collapse. After replacing them, the chassis started smoking :D
I know most people dog on Matsushita monitors, but the tube on this one is beautiful with zero burn in, so I'd like to get it going.
Let me know when you test them :)
Thanks in advance,
Phil
Heh
Usually if a tube from that era has little to zero burn, then the monitor didn't work for very long :(
Or it's a game that doesn't sit on screen and burn.. Good luck man, those are super shitty to work on.
So I've heard...
That's one reason I decided to see if someone had a working chassis to see if that corrects the problem rather than shotgunning this one anymore than I have already.
Hopefully the one of the ones billybob has will fix it :/
Nope, both of mine have issues.
1: Now power at all has tag not from me that says "bad Fly-back" Didn't notice till after I pulled the chassis that a fuse was missing. Tube did have "game-over" burned on the screen so it was working at one point in time. Didn't feel like hooking it back up to blow a fuse.
2: Powers on and can hear it running, but black screen. When it is powering off you can see a white screen for about a second.
that is as much as i looked at these things as i dont fell my time is worth it to fix them.
on a side note are these tubes compatible with any other chassis and yolk?
If you want to buy my 2 chassis $70 shipped to lower 48. Going to post them in the FS section with some other monitor parts. you have first dibs.
-Jake
