DO NOT run that cartridge over 5.1 volts if you are using an arcade switcher and a Capcom I/O. The tiny surface mount buffer chips on the cart are easy to damage and will start to flake out & die if you run the cart at 5.2 volts or above.
Cheers for the info... I do have the Capcom I/O in my blast city. Where should I be measuring the 5 volts. In my jamma cabs I measure at pins 1 & 3 on the board
