Anyone have an extra laying around they want to sell?
There is a new LV2000 lite on the LV2000 site for $27 shipped. The only difference from the regular one is that there is no voltage adjustments.
http://www.vector-repair.com/
LV2000 Lite. Do you want to loose the capability of adjusting the outputs just to save a couple bucks?? Not sure if that's the intention???
...and I *always* have LV6100s in stock...
This is not "competition".
It's just a rehash of his old design with the same design defects as his old design. His surface mount diodes will continue to fail at a much higher rate than through-hole diodes, and his resistors will continue to change value with age and the voltages will drift -- you just have no way of correcting for the drift anymore (not that the absolute value of the voltages is all that important.) He's still using the SMD regulators which handle less current than their TO-220 counterparts, so they're more likely to be damaged by repeated power-on transients.
Um, yeah.
Hey Robran68, did you see that swim-suit was just auctioned off recently!
