WTB Killer Instinct Control Panel
NY321
Scotia, New York
Rating - 0%
0   0   0
Hi i am putting feeler out there to see what my best option is.I would like a killer instinct cp for my midway style cab (or similar 2 player 6 button that would fit).I dont know how to build one but if comes down to it i will try to butcher one lol.Im trying to avoid that.Pm me thanks.
If you have nothing to start with, buy a pre cut lexan template http://forums.arcade-museum.com/showthread.php?t=223290
Use that to cut your wood (3/4" mdf"). Clamp the lexan to wood, use a spade bit ( 1 1/8" ) to cut your holes. Laminate the wood. Route the holes out with a router. Order a new decal from gameongrafix.com . Order new screws from twistedquarter.com . Order joystick/buttons from tornadoterrys.com
Are you restoring a KI? Or building a Mame?
Well i got a Mace and im getting a xxxx in 1.It sounded easy enough to make one but i started 2nd guessing myself lol thats why i figured if someone had one or similar be easier.Thanks for the info though i appreciate it.
Basically im looking for the top panel/wood etc for a 2 player 6 button layout like a killer instinct style to the midway cab.maybe with the 2 sticks/buttons spaced out a bit more than the KI (if makeing a new one).So i can just hook up my buttons and joysticks and bolt it to existing cp box.It soesnt have to have any graphics on top just painted solid color or whatever.Its for a multi game.
What would something like that cost for you to build 4 me just to give me an idea so i can weight my options?you can pm me the $ if u want.thanks.
you might be better off with a larger 4p panel that way you could fit a trackball in if you wanted.
I might have some more local options for you if ctozzi's won't work.
