WTB: kangaroo to jamma adaptrer
needhelp
Donor 3 years: 2016, 2021, 2024
Indianapolis, Indiana
I was want to buy a kangaroo to jamma adapter. If any makes them or has one that they would like to get rid of I would be interested in it. If anybody has a detailed wiring diagram of how to make one that would be ok too..
thanks
Are you trying to run a Kangaroo board in a Jamma cabinet, or are you trying to make a Kangaroo harness run a Jamma board?
The latter sounds better (with a 48-n-1 :) )
I have made adapters for boards to run in a Jamma cabinet, but they're time-consuming (for me) and should be priced accordingly.
I'd have to check out if I have the correct connectors- here is the pinout for kangaroo-
Kangaroo, Atari. Typed in by Barry Brumitt
2 boards.
56 pin logic board:
W - 5v Ret (ground)
19 - -Sense (tied to ground on PCB?)
21 - +Sense (tied to ground on PCB?)
Y - 5v
Z - 12vDC
D - invert (tie externally to 16)
16 - ground (tie externally to D)
C - sound (tie externally to 18)
18 - ground (tie externally to C)
T - Spkr Ret (ground?)
15 - Speaker
A - Start 1
1 - Start 2
6 - Punch
E - Left
F - Down
4 - Right
5 - Up
U - Ground (for controlls)
B - L coin
2 - R coin
17 - gnd
14 - Coin Ctr L
S - Coin Ctr R
J - Test
V - Gnd
Video Board (20 pins?)
H - 5v return (Ground)
J - 5v
K - 12v
L - -5v
E - Video Gnd
C - Blue
B - Green
A - Red
D - Negative Composite Sync
I am wanting to turn my kangaroo cocktail game into a 48 in 1 or a 19 in 1. and thought it would be easier to get a jamma adapter then to rewire it..
So you want to run jamma boards in your kangaroo cab right? I can build you that adapter but it will be up to a week before I can get it done. $20 shipped.
