WTB: Gottlieb Sound Board Qbert, System 80 Pin, etc.
Mark Hooks
Tallahassee, Florida
I need a heat sink for my Reactor audio amp board. I am hoping someone has a dead sound board with one still on it. Sound boards from Qbert, Mad Planets, early system 80 pinblalls, etc will work. It can be missing parts so long as the heat sink is still intact. The one I want looks like the one in the attached picture.
You can buy these at most electronic suppliers. Its just a TO-3 Transistor heatsink with an extra hole drilled in it. I will see if I can find you a link or two.
Not in stock at digikey http://search.digikey.com/scripts/DkSearch/dksus.dll?Detail&name=HS269-ND ,will look elsewhere.
Here you go, exact match. You will just have to drill one hole just as gottlieb did.
http://www.jameco.com/webapp/wcs/stores/servlet/Product_10001_10001_151547_-1
Thanks, I assumend they were no longer available. I'll order a couple if I can't find a parts board.
