keithsarcade
WTB Gorf PCB & Trim Piece, and maybe a marquee...
I am in need of at least the CPU at J3, and probably the main CPU at J6. I know for sure J3 is bad, and since I'm getting no sound with 2 good amps, I'm getting advice that J6 is also probably bad. Ill look at either, or both, or a complete boardset. I do know my smaller RAM boards and the pattern board is good. Would welcome a swap + cash for a fully working set.
I am also missing the aluminum trim piece that mounts between the bezel and CP.
Might also need a marquee. I made the mistake of washing mine (it was nasty) and all the red from the GORF logo flaked away. I might try to save it, but if anyone has a good one reasonably priced, Ill look at it.
Also curious, is there repro "interior" side art out there? You know, the blue panels that go on each side above the bezel? Not a big deal but my LH side is a little beat up.
Almost forgot, could also use the joystick insert. I remember someone posted about an early run with text instead of graphics. Anyone have anything?
