I have a control panel that has the instructions kinda rubbed off. But a new overlay can be applied. Also, the control panel and the plastic bottom piece are two separate pieces and aren't a part of each other.
Ah, I see. So I take it you have the top portion only? So the bottom transparent section slots in or bolts into the top section then? Any idea of where to find one? Thanks
I crushed one and I probably saved it. But getting to it would be a real pain. So if you can find it from someone else, go for it. It will take me weeks to look for it and I am not 100% sure I have it. The only plus is I am semi local to you.
