crassvw
looking to buy a Ghosts 'N Goblins marquee and a cpo for a project I am working on. I need the marquee (lit from behind, does not need to have adhesive backing, and no plexi glass preferred) to be 21in x 7in, and the CPO needs to be 21in x 11in (I want it to come down the front a little) and it needs to have adhesive backing to stick on the front and control panel, and button/joystick placement is not an issue, I can work around that.
Like I said, this is for a project, so it does not need to be restoration quality and not trying to break the bank, I would like it to look good for as long as I use it. So if you have what I need, or are able to print it please contact me. Also looking for a Galaga marquee and cpo with the same dimensions. http://forums.arcade-museum.com/showthread.php?t=217005
