WTB - gauntlet locks and t molding
I'd like to know where to get the lipped t-molding that went around the CP on the original Gauntlet. It was like normal t-molding, but it had a rounded lip that came up and over the edge of the metal control panel sheet and overlay.
Arcadeshop as Shawn pointed out has it. Around $10 for the entire CP. It will take a little bit of caution on the bottom side as I cut it around the bends and than used staple guy to staple it into the T molding from the bottom. I also used a heat gun very carefully on the tops of the bends as the sharp bends tend to want to lift. The heat gun helped soften and drop the sharp bends sticking up. Once done, the CP looks like new.
