WTB: Gauntlet 4 Player Metal Control Panel
ceelston
Donor 2012
Texas
Rating - 0%
0   0   0
I am looking for the metal portion of the Gauntlet 4 player control panel that attaches to the wood without any extra holes drilled or cut. I believe the Gauntlet 1 and Gauntlet 2 metal portions of the control panel are the same (correct me if I am wrong), so either will due. If you have the wooden portion as well, I might be interested if it is in better shape than my own. I would be especially interested in the whole ensemble if it had t-molding in good shape, as mine is in great need of replacement. If the CPO is in good shape, even better!
Please PM me with a price and shipping costs to 47906 if you have one available and I wouldn't mind photos if you have any. Thanks!
You are correct sir.
Gauntlet and Gauntlet 2 have the same control panel set-up.
I had a fully populated control panel about 3 years ago but sold it off.
Do you need anything else to complete your Gauntlet project?
Good luck on your search.
I finally picked up a set of joysticks in decent condition and did a full disassembly, cleaning, and greasing... those things were physical in good condition, just really dirty from years of use. It's more or less operational, but I do need some of the following:
1. Leaf buttons and bases (I have a few leaf button bases, but no buttons themselves and am unsure which to buy when I see them various places online)
2. Sound related harnesses. I finally found a board, but I don't have the harness between power and sound or the one between main board and sound board. I may have to make one since it's surely more expensive to buy an original.
3. Original power supply. I am using a switching power supply which works, but is not ideal. Also, I am unsure what the results will be using a switching power supply vs linear with the sound board. I have the power supply base, transformer, and fuse slots, but everything else was removed prior to me getting it and a 15v power supply is impossible to find.
4. Original coin door eject buttons. The ones I have are in rough shape and since so many variations of eject buttons have been made for arcades over the years, it is difficult to find a match that will fit. Mine are mostly operational, but between serious scuffing (looks like someone took sandpaper to a couple) and some being melted, probably by cigarettes, they're in rough shape.
5. Vinyl wide enough to fit the sides with similar texture to the original. I can't see the texture or opacity of anything in the photos they provide for online shops.
If you have any old stuff sitting around, I wouldn't mind hearing from you.
I've got the complete wiring harness for the internals.
There's a total of 6 of them.
I believe I have all 4 of the coin reject buttons.
And I have the original switching power supply.
Pm sent to you.
I have 2,
They actually have the Gauntlet 2 overlay on top of the original Gauntlet CP image.
