WTB: G07-CBO Chasis
jeff412
Buna, Texas
I need two good G07-CBO chasis. I have a Qix that's missing the chasis and a Pacman with a cracked chasis PCB.
Jeff
Riptor,
When you patch a crack. Do you span it with solder or with wire?
Jeff
On a typical crack you can just bridge some solder across it. If its something thats going to have some load on it you might want to use a piece of wire to give it some extra support. If the track is burned you will need to jump it with wire. Here's a couple pics of a GO7 neckboard I did a while back. I epoxied the board together first since it was broke all the way through. Its still running strong.
Ok. You talked me into it. I went ahead and repaired the crack, replaced the flyback and the HOT and now the thing actually works. Still need to get a horizontal width coil, but it looks pretty good. Thanks for the prodding.
Jeff
