WTB: DKJr Control Panel, Dr. Mario Marquee, Super Off Road Track Pak PCB
pmagames
Kelso, Washington
Looking for the following:
Donkey Kong Jr Control Panel - Found one
Donkey Kong Wiring
Dr. Mario marquee
Super Off Road w/ Track Pak PCB (Would even take a working Super Off Road without the Track Pak!) - I need this one ASAP!
should have no problem finding most of the stuff on your list. Bob roberts can build you the wiring harness.
the super off road track pack is a brutal find though, good luck with that one.
Thanks.
I had posted a few times looking for a working PCB a couple months back, but I didn't get any bites then. The PCB I have now turns on and plays, but you can't see the trucks on the screen, it's pretty weird.
I have some of the Donkey Kong cables if you're looking to go the original multi-connector route :
http://forums.arcade-museum.com/showpost.php?p=1637903&postcount=2
Well, I found a DK Jr board and had an extra Mario Bros in a DK style cab, I need all the necessary harnesses that I would need to make the switch. Do you think it would work with those, or would I still need to find additional ones? I'll have to look at my Donkey Kong cabs to see how they're set up so I know exactly what I need, I should have done that in the first place.
Bump
