Also FYI, you want to be really careful with these (and coin door parts in general), as doors and parts are often more different than they may appear.
There are two major brands (CoinCo and Coin Controls, and they are not the same company). CoinCo (also known as Coin Acceptors) was US-based, and their parts were SAE. Coin Controls was based in the UK, and the parts are metric, and are slightly different sized as a result.
However I've also found that parts are not always universally interchangeable within a given brand, as the door styles and models varied, and the parts can differ just enough for them not to fit (and drive you crazy). So, you want to confirm you have the right parts, with good pics if possible, and cross reference them to the appropriate manuals. (Most of the door manuals are online, and have good exploded views, with part numbers for everything, which I've found to be a good resource to use when communicating parts info).
This is probably one of the reasons contributing to why nobody has reproed door parts. There are just too many variations. I've found the best solution is to just keep a stockpile of multiple different parts doors, which I can steal from as needed.
Anyway, YMMV, but just a heads up.
