Welp... this is what I have:
2 coin door frames.
3 upper coin doors.
2 lower coin doors.
Unfortunately 2 of the upper coin doors won't fit the nice metal bezels I have.
The one that does fit the nice bezels I have won't fit in the frame (the damn hinge is about 1/2" longer!!
So I am screwed.
From what I gather there are at least two types of over/under doors. One with a plastic bezel (I have 2 of these types of doors) that utilize a button with a thinner "post" and a slightly smaller size... and another which uses a metal coin bezel with a thicker button "post" and it's a tiny bit bigger than the other. It seems that the doors with the metal bezels don't fit the two frames I have here...
What I need:
All parts associated with the door that uses the PLASTIC BEZEL... aside from either door and frame. I need the plastic bezels (2 coin and 2 return)... the buttons themselves... the coin return flaps...and the hardware associated with both the coin insert bezels and the coin return bezels (the back side of the coin door hardware that is used to hold all the stuff in place.
Essentially... I need it all aside from the doors and frame.
BTW... what went in a Star Wars, the METAL bezel doors or the PLASTIC bezel doors?
Check out this post for more details: http://forums.arcade-museum.com/showpost.php?p=1661652&postcount=10
2 coin door frames.
3 upper coin doors.
2 lower coin doors.
So I am screwed.
What I need:
