Wtb: Cisco heat marquee
scott1982
Omaha, Nebraska
Picked up a Cisco Heat for dirt cheap fully working for 50 dollars but the marquee is in bad shape. Looking for a cisco heat marquee. Pm me with details. Thanks.
When I saw your post I remembered I had parted out a fully working Cisco Heat in a damaged cabinet. I went searching for the marquee and couldn't find it. I found the PCB, the front glass and other parts but no marquee. It was driving me crazy because I know I had all the parts, which I usually keep together when I part out a game. Today I see another post about Cisco Heat and it reminded me of why I couldn't find it. BECAUSE THERE IS NO MARQUEE (at least not on the version I had).
See picture here: http://forums.arcade-museum.com/showthread.php?t=133647 The one I parted out was the same as pictured. What version do you have that has a (missing) marquee? Sounds like it was a conversion of some sort.
Now if you need the front glass or the PCB or the red/white/blue topper, I can help you out.
Hmmm..after further investigation, maybe you have the UK version (which has a marquee)? On arcadeflyers.com, I found these two versions of the upright:
USA:
http://www.arcadeflyers.com/?page=flyer&db=videodb&id=2917&image=2
UK:
http://www.arcadeflyers.com/?page=flyer&db=videodb&id=1673&image=1
