Hello -
I'm begrudgingly looking for a different donor B-board for the CPS2 multi. The donor I was planning on using for a friend's multi was all set and ready to go, and then I discovered that it was missing the CN6 socket (93646B-3) and apparently never even had one as the board is clean. I'm assuming that on some titles, that socket was not needed and to save money, Capcom didn't include them on all B-boards. I found a post on AP from 3 years ago where someone ran into the same situation as I did, and Darksoft replied saying he has only seen one or two B boards without this socket...so...back to the search for a different donor.
I do not care if the outer shell case is cracked (heck I don't even need it), my ask is for a known working B-board, pretty much any revision will work - as long as it has the CN6 socket!
See below for an example, thanks!
