WTB: Bosconian PCB
If I understand correctly, you may be better off just looking for a working Galaga Board and then ordering a complete rom set from hobby roms. Pretty sure its the same board.
I think the video board is different, but I don't remember for sure. I've got both games, but have never pulled the boards to compare them.
-JM
a Galaga board is probably going to be more expensive than a Bosconian, though neither will be real cheap. i picked up mine from a local collector at the same time i bought a cab from him for $50 or so. i've seen 'em go on eBay and here for $50-$80.
It would be cool if I could find someone to repair mine... I have a non working galaga board also and they look very similiar.. I can play Mappy in my Bosconioan cabinet. LOL
Not that its cheap, but I have had good luck with GLS-1 on ebay. He fixed my Galaga. I think it runs 125 for the repair, but it is burn tested. He could probably fix your Bosconian. Wouldn't hurt to look into it. Although, I know its probably more expensive than what your looking for. Best of luck.
You might check with Channelmanic and see if he can fix it for you. Pretty much the same hardware as Galaga. he does top-notch work.
Thanks for the Pr0pz Pat!
It's the same hardware with a couple extra chips soldered into the board.
RJ
