Gravitar harnesses can be modded to be used with BW (which is what most of them were, being conversions). The Atari conversion docs instruct you to add the extra wires needed for the additional controls. I'm not sure if there were any 'dedicated' BW harnesses. (There may have been, I just haven't seen one, and have no data either way.)
However, a better, cheaper, and more available option is use a Space Duel harness, which already has the extra control wires. Depending on what you are using for a CP harness, you may or may not need to re-pin it to fit the SD harness, or build a CP wiring adapter (which you don't need to do if you just re-pin the harness). Biltronix has detailed documentation here, if you do want to build the adapter, but it's usually just easier to manually wire the CP up, especially if you're building one from scratch:
