WTB Bestech chassis
I think if you get a hammer and tap it on, it should fit fine.
Either that or get that same hammer and nail three new pins into the end of the tube so you can use the 10 pin chassis. 17 gauge bright finish nails should do the trick. You'll have to hit the end of the tube with a good deal of force to do this, because the glass is hard. Safety first though...make sure to wear eye protection.
Ok I'll try and see if it works. I did not think of that
its not a no. i have to find out if it is compatable with my neck? i have a 7 pin neck. plus can you make the power chord into a two prong molex? I will buy it off you.
Power cord.
...PLEASE!!!
Why would a seller know if the chassis fits your tube from just a photo if you can't?
There's a simple solution. Buy the chassis in Shawn's FS thread.
If it fits, great! If it doesn't just resell it.
No idea if it will work on your setup or not.
Yes I can make the power cord compatible with a 2-pin connection.
Power cord.
...PLEASE!!!
Or just throw it away like the other ones.
