WTB Atari Gauntlet 2 Power Supply
Based on my own Gauntlet II, a regular screw terminal switching power supply works for these.
At least that is what is mine (was that way when I bought it).
He is correct.
Tie the red wires and the red/white wire to +5V and the brown wires and the brown/white wire to GND.
I'll get you a picture of the power block you asked for a little later today.
Do you have an original Gauntlet harness or is it an after market?
Can you post a picture of the wiring you have going to the power supply.
Here's the power block photograph you wanted.
Any other wiring please let me know.
If you take a look at the photo you can see a total of 6 wires going into the switching power supply.
On an original power supply the intakes are labeled as (+), (-), +S, and -S.
The attached photo shows what I'm explaining.
If you attach the +S and (+) to +5V on a new switching power supply and the -S and (-) to GND you'll be good to go.
Obviously make sure your two live wires: black and white go into the AC1 and AC2 connections too.
I got a complete reproduction harness from Level99.
