The point of the OP's request is to preserve an original monitor.
There's a difference between wanting to preserve the originality of something for the fun and the challenge of preservation, versus 'just making the game work' by whatever you can hack together.
Props to 64B1T for pursuing the former.
Bump for a Disco chassis.
Yeah. At this point, I just want to play I, Robot so I'm going the GO7 route, but I'm going out of my way to make sure that this GO7 stuff doesn't modify the disco frame/tube/yoke in any way and I can pop a disco right back in.
If I were to get another chassis, it's my hope that I'll be able to better determine what happened to mine. I suspect at this point it might be one of the weird internal flyback diodes marginally failing, but that's just a speculation. Even one where the flyback was known dead might be helpful... If I transplanted my flyback and it does the same thing on another chassis, I'd know for sure that was the issue. But I'd prefer a working one
When it worked, it was the nicest picture out of any monitor I have. If I could fix it on my own I would (and I'm not going to give up either. Now that I know I can use the G07 on the disco frame, the reverse should be true. So maybe I can prod it on the bench.)
Still, would like to find another chassis if I can and keep this thing going. If they're really so hated, send them to the Retrobotics home for weird monitors![]()
No need to come in and translate what "the point" of the OP is. I get it. He wants to fix his Disco monitor - that's cool. I never would have even mentioned the G07, but the fact of the matter is he was clearly willing to try other things when he started to experiment with a K4900.
Dead Atari Disco - B+ Issues - Kills IC401
As another data point, check the voltage at the cathode of Zener Diode D402 (HZ36-2). With B+ at 115V, the voltage drop across R427 is 80.8V - resulting in 34.2V to D402. Referring to a HZ36-2 data sheet, the minimum and maximum Zener voltages are 35.3V and 36.8V respectively. If the cathode...forums.arcade-museum.com
Not sure what "hacking" you're referring to when it's just swapping a chassis. Man, if that's considering "hacking something together" then I'm quite the hacker. All of the buttons and joysticks that have been replaced... damn!
Nothing wrong with wanting to preserve an original piece of hardware. But there's also nothing wrong with wanting a working game you can play.
Like I said before to the OP, good luck in your search. I hope you get your game working the way you want.
I unfortunately don't own any three pot 4900 chassis to try this with. Only four and five pots. But in any case it ran long enough that the tube is definitely getting ruled good here. If the image was good enough I would have left it as is for now.
Oh wait...
Yeah, sorry for even mentioning the G07 compatibility.
And even more in DMs ;-;Hacking something together, and then leaving the original boards in the bottom of the cabinet so you can say 'LoOk, i'M PrEsErViNg iT' is a lazy excuse that gets used far too often.
The OP spent an entire thread trying to figure out how to repair the Disco, for the sake of preserving a monitor. The point of this thread is to get a specific chassis, that might even help him repair the other one. And then we all might actually learn something.
The next guy can be me too! I often scratch my head at the weird shit that past me does that I have to unfuck.If you want a G07 in your cabinet, pull the whole monitor and install a fucking G07. But hacking shit together because you 'want to be done with it and not look back' is HACKY.
I know this because I deal with other people's hackery regularly. People think just because they got something working, they're done, and how they did it doesn't matter. But you don't think about the next guy, who is going to need to figure out WTF you did the next time it breaks. And that can be 6 months from now, or decades from now, when you're dead and all of your shit gets sold to someone else, and the knowledge of what you did to the cab gets lost.
I'm taking this damn cabinet to my grave. It's not getting the best of me!What happens when that monitor breaks again, after the OP is done owning it?
Maybe I should put a label on the chassis. "This has been extremely fucked with."Someone has to figure out what hackery was done, in addition to whatever actually is wrong. And it won't be obvious if what's wrong is due to the hacks, or some other normal failure, which makes troubleshooting a lot more difficult.
Or what happens when that chassis unknowingly ends up back in a G07 at some point, and the width is way off. Someone will waste a lot of time looking for something that isn't obvious, because they don't know to look for it.
Man I've been here four years, how long until I'm not the new guy? lolToday's repair people ARE the next guy. And with every repair I do, I'm always thinking of the 'next' next guy. Being a good steward of these games not only includes getting them working, but doing what you can to think about the FUTURE of the game, and making it easy for the next person to work on it, whether that's 5, 10 or 50 years from now. THAT'S why good repair practices are important.
I don't fault Liam here, he's new and doing his best to learn. Good on him. But shame on anyone who has been around this hobby long enough to know better, and encourages hacky practices.
What happens when that monitor breaks again, after the OP is done owning it? Someone has to figure out what hackery was done, in addition to whatever actually is wrong. And it won't be obvious if what's wrong is due to the hacks, or some other normal failure, which makes troubleshooting a lot more difficult.
Sorry if you don't like my opinion. You aren't going to change it.
That would be incredible thank you!no promises but i think i have a disco chassis i will dig around for it. i dug it out of a buddies scrap pile a few years ago he said it was outside in the weather for about a year its free + shipping if i find it
Those double heat sync and colored knobs look really familiar to me. I will have to see how hard it is to get to the trailer with chassis in it.That's an amplifone Raster. Firefox, TX-1, and some Crystal Castles machines used these.
My Firefox has one as well, but the Flyback blew, so its running with a K7000 flyback.
That one looks like a different revision than mine, it's missing the PLL PCB. It looks like they integrated that circuit into the right side of the PCB, so this must be a later one. I haven't seen one like that before. Interesting.
Here's a shot of my Disco. Sorry for not including it earlier. From what I understand, this was Atari's second attempt at an "in house" Monitor, even though it was contracted out. Didn't seem any more successful than the first..
