I am 90% sure I have a Asteroids Deluxe if that would work for you.
-Jake
I think I may have several that I picked up in a bulk buy. Unfortunately, I have no way to test them. I'll update with a pic and you can let me know.
Thanks!
I've heard guys say on several occasions that color vector and any other atari power brick are the same. Worth checking out.
EHHHHHHHHHHHHHHH (obnoxious buzzer sound) Wrong. Atari color vector power bricks are not interchangeable with other Atari power bricks. Atari color vector bricks can be used with any Atari Color vector game. That is probably what you heard and misunderstood. You need to add a connector for the 120 V AC on some of them if it doesn't have it and you plan on using it to power a cooling fan in say a Star Wars but those pieces are easy enough to reproduce.
Check elecktronforge.com for their power brick listing and you will see that the transformer assembly is the same for the color vectors The ac power put out by the transformer is the key. To confuse things a little more, some atari raster power bricks can be made to work with Black and white vector games. Let's leave it at that.
Here is a link to elektronforge's page.
http://elektronforge.com/transassy.htm
Finally, I have some power bricks but they are untested and probably need repair. I'm running low on them. Most were rescued from games that had been converted in the past. I'm planning on converting them back at some point. If you want one. PM me for details.
