I looked for awhile when I needed one but the only ones I found were like $50+ each. So I ended up just picking up the parts from Bob Roberts. He had (don't know if he still does) a split fingerboard pre-soldered to the 44 pin connector. The only other thing you'll need is a 12 slot (might only be 10, can't recall right off hand) linear molex connector to run the power lines to separately. Took less than an hour to put together and it works great.
