connectors are not the problem, pins are the problem
Are they not a standard like Molex or AMP?
It appears I'll just have to get a 72 pin and cut it down to size.
I did a quick search of the Pinouts for games and it appears that Q*Bert is the only one that uses 60 pins. Would be interesting to know if any more are like that though.
Most seem to be 22, 36, 44 and 56.
I have 72 pin SEC. You can cut them down but you just have to be careful when you plug the board in to make sure its installed correctly since it wont center itself.
Im sure there are others but the only one I know of for sure is Mad planets which basically looks just like a qbert board. It might be the same board, dunno.
