WTB: 27" 25Khz/31Khz (VGA) monitor (Central FL)
brandogg
Basically I want to put my Dreamcast inside of my Konami Viper (Warzaid/Jurassic Park 3) cabinet so I can play House of the Dead, etc. I realize I could probably take the VGA (or RGB) output of the Dreamcast and scale it down to 25Khz, but ideally I ld be able to use a switching monitor thay lets me keep the Viper PCB and Dreamcast connected at the same time, so i think a monitor that supports med/high res (VGA) is the way to go. Thanks!
would this work? and in kissimmee. (not mine, just passing on the link)
Yes, that's a Wells Gardner D9400. That WG series (9200/9400/9600/etc.) has connections for both standard and medium resolution as well as VGA input. I have several of them available as well.
Got any for $200? :) IIRC these need to have a harness flipped if you're going from CGA/EGA to VGA inputs...wonder if I could rig up a switch on the outside but maybe I can reach the neckboard from the coin door.
