I need a few power supplies that hook up directly to the 1xxx-1 multicade boards. Anyone have any available or know where I can purchase these directly?
Yeah but the game board has that 20 pin connector. The game board has its own atx power supply with the 20 pin connector and then everything else runs on a separate power supply. I need the own that can hook up into the game board.
Just use a standard ATX power supply,the 20 pin plug will power the mobo and the peripheral power connectors(ie power connectors for harddrives ,CD rom drives)can be used to supply 5v and 12v to the jamma harness or what ever else you need those voltages for.Yellow is 12v red is 5v and black is ground
this is one of the better deals ive found for new supplies. THese work well on xx in ones, red board golden tee, and i would assume almost any other gameboard that runs on a 20 pin, 24 pin, OR 4 pin connector.
