WTB: 13" Monitor for WARLORDS COCKTAIL
fizgig
Permanently Banned for constant cyber bullying. Ge
Murrieta, California
Anyone have or know where to get a monitor for a Warlords Cocktail?
What monitors will work for this? Atari, Sanyo, Wells Gardner, or ?
thanks,
Dan
Will this one work? W/G 7700
Will this one work/fit?
http://www.happcontrols.com/monitors/49054800.htm
SPECIFICATIONS
CRT Size (Diagonal Measure): 13", 19"
PHOSPHOR Type: P22
CRT Etch: Polished Faceplate
Striped Trio Spacing: 0.42mm & 0.63mm (13"), 0.71mm (19")
INPUT SIGNALS
Input Connector: 0.156 Center Head
Video Type: RGB Analog
Video Input Impedence: 4.7K Ohm;
Video Level: 1 to 5 Volts Peak-To-Peak
Sync Type: TTL Sync; Separate Or Composite, Negative Or Positive
Sync Input Impedence: 20K Ohm for Positive, 12K Ohm for Negative
Horizontal Sync Frequency: 15.75 Khz
Vertical Sync Frequency: 47 to 63 Hz
POWER INPUT
Input Voltage: 90-264 VAC, 50-60 Hz; No Isolation Transformer Required
Maximum Power: 70 Watts (19")
USER CONTROLS
Remote Controls: Brightness, Contrast, Horizontal Centering, Vertical Size, Vertical Centering, Vertical Hold
Internal Controls: Horizontal Hold, Horizontal Size, Focus
MISCELLANEOUS
Operating Temperature: 0 to 55 Degrees C
Agency Compliance: U.L., C.S.A., D.H.H.S. Radiation Performance Std.
RESOLUTION
Graphic Modes: 640 x 200 (May Be Limited By The CRT)
Video Bandwidth: 12 MHz Typical
don't forget, the 14" Sanyo is the same size as standard 13" cabaret or cocktail monitors.
Though a standard 13" will work in this machine, i can tell you that a GO7 13" does not have the same size tube as a Sanyo 14" I have em both here (the sanyo is from my warlords) and it's definitely larger than the GO7
