WrestleFest playing blind, need suggestions.
RetroInjection
Sayre, Pennsylvania
Hi, guys.
I am trying to help a friend figure out what's going on with his WWF WrestleFest monitor. I couldn't find a make or model number while I was over there, but it had no neck glow whatsoever. The game plays blind. He told me that he was playing it one day, and the monitor just shut off. Any ideas on what this could be? Do you think that swapping it out for a WG25k7000 would be a good idea, or is this something that's likely a power issue? Any help would be appreciated. Thanks.
Dave
It probably already has a WG25K7000 in it. The monitor chassis probably has a blown fuse because the flyback went bad, or is in high voltage shutdown because the caps need replaced.
75% chance it's already got a WG25K7000 in it, so if you have one of those, you could just swap the monitor chassis and leave the tube in it. The rebuild the chassis for your tube.
yea K7000's are fairly easy to work on, and when the get a rebuild they will last along time.
take some pics when you can and we can id the non working chassis.
if you need it rebuilt and need help i can rebuild it for you.
Peace
Buffett
