WoW wiring question...
Wolfinator
Lethbridge, Alberta, Canada
The pinout on the output side of my RGB interface is as follows:
RGB Interface Board (9-pos, 0.100"?)
(to & from Monitor)
Pin | Definition
1 | Gnd [to monitor RGB Gnd]
2 | Red
3 | Key
4 | Gnd
5 | Green
6 | Gnd
7 | Blue
8 | Gnd [to monitor Sync Gnd]
9 | -Sync
Note: Pins 1 & 2, 4 & 5, 6 & 7, and 8 & 9 are labeled "twisted pair" on the
schematic for the RGB Interface Board.
I am wondering how that is to be wired into the monitor plug, as the monitor plug only has 5 wired going to it. I don't have the original to compare to, and may end up having to re-create it...any ideas?
Thanks in advance!!!
All of the grounds tie together. They are twisted pairs to block interference, although since its not a differential input on the monitor, its not very effective. Your 5 pins are R,G,B (All the Grounds) then -Synch. You'll probably have to tie the -Synch to both H and V synch pins.
Like he said, there are several grounds. If its the same as gorf, the ground wires are white.
