Tighe
I just went to unplug the neckboard on this 19" K7000 (K7901) from my Super Hang On and Hissssssssss.
What tube can I use with the chassis?
pretty sure you can use any tv tube with the same yoke resistance, or you can transfer over the yoke from that broken tube there.
if it a k7000 small neck grab a daewoo, emerson,sylvania,durabrand,symphonic tv. 2000 and newer, the tubes are great for direct drop in. to measure the yoke put your meter on ohm and test the green and yellow then the red and blue, that will tell you if your close. also you might have to splice in a new yoke connector.
I've never heard of this happening, either you've pulled it off very hard or the neck already had a hairline crack in it.
1.3 is pretty damn close if you ask me but i'm no tv tube swap guru like some of these other guys. you can always swap yokes.
Imma gonna do it!
if it don't work it don't work, if it does /victory lap
