Would there be a reason why a change machine wouldn't be working?
I'm set to get a change machine from an individual that says it doesn't work.
He mentioned that the unit powers on, but it won't accept the dollars when inserted.
Any suggestions?
Here's the message he wrote me describing the machine:
This is a change machine that you would normally see in an arcade or laundry.
The Bad News:
There seems to be a power short (Replacing wire may fix it) but it does run
The bill accept portion powers up but won't pull in the bill (Wire seems to be missing from the side, may be why)
No key (but it's open)
The Good News:
It powers up
Here are some picture too if someone by chance happens to have the manual they could send me to trouble shot the problem.
And also I have not gotten a chance to look at the machine.
Any help would be appreciated.
Thanks in advance.
Any suggestions?
The Bad News:
The Good News:
It powers up
Thanks in advance.
