World rally optic board
nitrocow
friday harbor, Washington
I have a world rally in a pole position cab and the steering has stopped working all the gears move like they should I've cleaned the optic any other ideas before I hunt down a new optic ?
When you go into the setup / calibration menu does it respond at all? I had problems with mine and eventually just ordered a new optic. The only problem I am having though is that I can do the drifting / fish tailing when making sharp right turns but it doesn't do it as easily when making the sharp turns to the left. When I go into my setup / calibration menu the wheel works perfectly. I tried two other boards and it does the same. It's so weird and annoying.
Robert
Where is the best place to get an optic ?
Okay, so I believe this is the optic you need. Just check the little PCB optic board and make sure it's the same number of pins. Mine was 4 and 4 (8 total) pins.
https://www.digikey.com/products/en?keywords=365-1719-ND
However, I now remember that I still had issues so I replaced the entire optic pcb board. I ordered those from suzohap. You get the new and improved version of the original pcb optic board along with a new optic already installed. Here is the link:
https://na.suzohapp.com/products/trackballs/A052-1011-00
I hope this helps.
Robert
