World Cup Soccer 94 question - Pin n00b here!
Riggy469
Massachusetts
I recently bought a World Cup 94 and I've found something I'm not sure about. When playing the game, the flasher lamps work fine, as does everything else. Yet, in the menu tests, the Flasher lamp test does nothing, and the tests that check the flippers/kickouts/etc do nothing (except for the goalie/soccer ball test, which work fine). All of these things work as they should during normal gameplay. Any ideas?
Also, it says I am running revision LA-1 and sound revision 1, is there a more current software revision then those? Is it just an eprom swap to upgrade?
When the coindoor is open, the 50v is not active for safety. You need to push in the interlock to get that to work.
Pretty sure that is it.
Thanks! That was it.
This is my second pin, I used to own an TAF about 6 years ago, and I swore that all those tests ran with the coin door open.
Thanks for your assistance on that issue. Anyone have any idea abou the ROM version question?
