World Cup 94... Picked up my Grail Need Help
Simple Green is fine for the playfield. It will cut through the crud quickly. Then polish with Novus 2.
I PM'd you a couple of links that might be helpful in regards to cleaning the playfield and your battery holder issue. I recently did a full teardown and cleanup on a WCS94, so if you have any real specific questions, feel free to shoot them my way.
Someday I will have a WCS.. I am jealous man. I see nothing in those pictures that cant be brought back to great shape with a little effort.
So did I brother - so did I. WCS94 has to be one of the worst machines ever to re rubber. It took me about 6 hours to tear mine down, clean and Novus the PF, install Cliffys (which you warned me about being a massive job and you were right), cleaning and Novus the ramps and then putting her back together.
I've had problems with my Cliffys losing the adhesive. Cliffy emailed me some new adhesive strips and told me to use rubbing alcohol on the adhesion spots before applying adhesive strips. I did so and low and behold the damn things poppped loose again. GAH! I went to Home Depot and found DAP sells adhesive strips. I brought those home, traced the protector and cut them out and laid them down. Those are 1000% better than the 3M stuff Cliffy supplies. I didn't bother Cliffy with it because he was already generous enough to supply strips for free.
Yeah, I've had some Cliffy protectors lose their stick. I'll check out those DAP strips. My LOTR has a Cliffy that came loose and it redirects a slow moving ball.
But yes, installing a full Cliffy set on WCS94 basically requires a full teardown.
Does anyone happen to have a list of the rubber kit for this game? I can't find it in the manual or on the web. I really don't want to have to measure every one of these and then place an order. If possible I would like to order all the rubbers for it before I tear it completely apart.
