Working on cleaning upa DK3 machine...
Rorvy
Minnesota
I need some direction on where/what replacement lock i can get to keep the coin door closed as well as was color and type of orange paint for the cabinet. Any and all advice is greatly appreciated.
As for a lock, a 3/4 inch standard tube lock will work, but a 5/8" shaft works perfectly. Best to go with an original Ninty lock, as the 3/4" replacements that are out there make the door pretty sloppy. If you want it quickly, post in the wanted section. If you're fine with the slop, Twisted Quarter, Bob Roberts, pretty much any arcade supplier has the 3/4 inch locks. As for the paint, color match it with a swatch from the paint store. Or you can go with the vinyl kits Rikitiki sells at thisoldgame.com. I went red:
