Working monitor I just picked up
DURANGOKING
kenosha, Wisconsin
A couple of working monitors. Does zenith make a good product? The other is a sony .
Was told the zenith is worth some bucks. Would like to put it in a nice cab
Thanks for looking
Those are tube manufacturers - not monitor manufacturers.
The first one is a Wells-Gardner, either a K7400 (standard-res), K7500 (medium-res) or U2000 (standard-res). Looks like there is a label on the top of the frame with the model number. Otherwise look on the back left edge of the chassis for a sticker that will say something like WGM2574, with 74 referring to a 7400.
The 2nd looks like it might be a Sharp Image monitor, possibly a KTMF. Look for any identifying stickers, perhaps on the back of the neckboard...
Modessitt
THANKS FOR THE INFO!! EVERY BIT HELPS. The one is a sharp image, the Guy had no use for them. Told me to take em both, so I did
Depending on your defination of "bucks".....someone told you wrong. That monitor is no different that any other 25" or 27" (can't tell what size they are from the pictures) monitor.
Edward
Edward
Well, a med-res may be worth more than a standard-res...
