what's wrong with your old one?
mh
I may be wrong but I think the "19v2000" and the "802" deflection boards should be interchangable.
The keys are ditterent on the connectors. What do you have to change?
it is an issue 5. I moved pin 4 and 5 on p500 and put the 802 def pcb in. Now I have a spot killer. with brightness turned all the way up, I still dont have a dot in the center of the screen.
I found it Mark. Thank you very much.
