Woohooo I picked up 2 Seeburg Juke Boxes today.
Dave27
Snohomish, Washington
I finally got my Seeburg USC-2 FireStar bandshell. Its in primo shape but someone robbed a couple of components off it.It needs the amp and the control box. Other then that it appears to be complete. If any of you have the 2 items I need please let me know. I'm not even sure if thats what they are called they are the 2 big units that mount to the back of the part on top that tips out. I need to buy some manuals for it.
The otherr is a STD4 Mardi Gras that I was told worked so I am excited to try it after I get them back together.I didnt take any pictures yet because I took them both apart today to clean the heck out of them. I'm wondering if I can use the amp and Digital Control center from the STD4 in the Firestar. I plan to sell the STD4 after I get the Firestar fully working....Any help appreciated.....Thankyou.....Dave
You know the story, pics or it didn't happen!
Now that's funny, Dave. I have those same two jukes in my garage. To answer your questions, yes you can swap the amp and digital control center between the USC2 and the STD4. You will need to reconfigure the mounting brackets, but it's a simple swap. All of the plugs and sockets are the same.
I gave up on my USC2 since it is too far gone, but am trying to get my STD4 going. Maybe we can swap some parts along the way to get us both a working Jukebox. Unfortunately, I've robbed the control center and amp out of the USC2 to put in the Mardi Gras, so I'm not of much help there at this point.
Keep in touch as you work on them and maybe we can help each other out.
That sounds good. To bad your not closer I bet if we had all four Jukes in one spot we would have two running in no time. Yah if I end up swapping some parts from the STD4 maybe you would want the rest of it.Just curious whats yours need. Does your USC2 have any good cosmetic parts mine look pretty darn good but if I found better ones that would be cool. Does your STD4 run at this time or are you still looking for parts for it.....Later.....Dave
My Mardi Gras is complete, but It isn't working correctly at this point. I can manually play a record, but I have an issue with the control center (I think).
The amp in the STD4 was dead, so I'm using the Amp out of the USC2.
If you have a working STD4 amp, maybe I could swap you the working USC2 amp I have?
The USC2 is pretty beat up. Not much on it cosmetically that looks good.
I'm at the point that I need to get one of the troubleshooting guides to figure mine out.
