FS Parts: Wizard of Wor parts
Teknotoyz
BUFFALO, West Virginia
OK, a few parts for a Wizard of Wor.
Complete Cabinet Wiring!! AC & PCB Harness: $65 shipped
Complete Wire harness, has some damaged insulation on a few wires which I will repair or can leave alone at your request. All connectors are in good condition, the only "bare ends" are the speaker connections which I unsoldered from the speaker terminals. I can install push on connectors for these if you would like. I will be happy to provide any pictures inside the cabinet to help in the install. This is a complicated wire harness!! RGB board and monitor connector wires included. Tried the RGB board but it gave a blue hue to the screen in my machine. I will include the control panel wire harness, but lots of wire ends where the buttons and joysticks were removed.
and also a:
COMPLETE AC WIRING. Includes all interlock switches, transformers, fuse block, and power switch. It is complete from wall Plug to the Bally power supply connector.
Audio Amp assembly - tested good - $40 shipped
Two memory cards - both give errors, for repair - $20 shipped for the pair
WoW Joysticks & Buttons: SOLD
Pair of complete Wizard of Wor joysticks. Balls may have some paint on them, but good condition otherwise. Will include a set of red/white leaf buttons.
These have the dual directional contacts required to play Wizard of Wor!
Good deal on the sticks. They are special to WOW and have a set of contacts per direction. It's the only way to properly play! ;)
