Wizard of Wor Help!
squall280
Pennsylvania
Picked up a Wizard of Wor yesterday. Started troubleshooting today. I own a Gorf so i troubleshot a few boards. First what isn;t happeneing.
I have a blank screen and no sound(Not coining up or anything)
All boards i could check in the stack work via testing with gorf. Can test the ram/ Rom and game boards obvioously due to different wiring out on those boards.
Rgb and power supply board both check out.
Any suggestions before ruling the game boards and or ram rom boards the problem?
So did you test all 5 boards except the main board in Gorf?? You can run Gorf in a WOW except the controls won't work so I would think the same for a WOW in a Gorf. What I do is swap one board at a time and fire it up to see what happens until the troubled board is identified. IIRC I could not go into test mode running the Gorf in the WOW cab, came up with a black screen.
