Wizard of War Help White Lines
TheMonarch4
Benton Harbor, Michigan
Need help with Wizard of Wor
The monitor has a white line that keep rolling up the monitor. See pic.
First step was to verify that it is not the monitor. I jumped the cabinet to other monitors
and the white lines are still there on the other monitors. Then I jumped a different game
cabinet to the Wizard of Wor monitor and there was no lines.
It would be safe to say that the problem is not the monitor
Step two confirm it is not the small video RGB board. A KLOV member was nice enough to send one to me
so I could confirm if this is the problem. I plugged it in an it did not fix the problem.
Step three. I replaced the entire cage with a complete differd board set and again it did not fix the problem.
The conclusion so far.
The monitor is OK.
The RGB video board is OK.
The board set is OK.
Any ideas what to try next????
Wizard of Wor
Update:
I realized that I had an extra power supply for a Super Pac Man. I saw online that the pinout was the same but had extra pins for 5v. I installed the Super Pac Power Supply and now the white lines in the monitor is gone. Wizard of Wor now working fine.
