Wiring help wanted in Central PA for $
Robochronic
Pennsylvania
Anyone near Harrisburg that would willing to come over and help me with the following for some extra cash?
First, the picture crapped out mid-play on my Omega Race upright b/c of the spot killer--the guy I bought it from thinks it's the molex connectors to the deflection board b/c he'd wiggle them (or gently tap the cab) and it would correct itself. I tried gently wiggling and then reseating the connectors to no avail, so I'm thinking one or more of the molex connectors needs to be replaced or, worst case, the wires soldered directly to the posts. He had redone the solders so the second possiblity of a cold solder seems less likely.
Second, the "100% working" robotron cocktail I picked up last year on fleabay arrived with the wiring for the adjustment switches cut off at the switch--hence no ability to adjust anything or run the self-diagnostics--and I need someone to help me wire them up to the board.
I'm still new to the hobby and learning my way through things but was hoping to be able to learn over someone's shoulder on these two projects. While the Omega Race makes a beautiful paper weight, it's even prettier when it's working. Any takers? If so, please PM me.
