Wiring harness
If anyone is willing to do this, Dokert is. He'd probably need detailed notes or a cabinet to go by tho
I tried dokert already but the problem is we have no template so he not interested since he wouldn't know how long to make the wires. I'll keep trying though. Thanks
Yes, I have the cabinet, cp, tube , yoke, monitor chassis, coin door, the pcb set, atari audio ii board, coin door, exhaustvfan, and switching power supply. I need a wiring harness, and whatever goes between the ps and the plug in the wall. Also could use the pcb cage but I know that's pushing it.
do you have the transformer?
720 needs a transformer as well to send power to the monitor, and 12vac and 18vac to the audio 2 board.
there is a picture of the whole power assembly in the manual, do you have a copy?
good question.. when i thought my transformer might be bad i tried to see if i could find anything on the market to produce the same outputs and i had no luck.. if you find a modern substitution id love to hear what works..or if any experts know...
here is what it is supposed to look like and do...
If Dokert wants to do this, then he could borrow my harness. PM if so. It's ugly, but it should be complete.
depending on how much it would cost to have a copy of one of these, i might be interested as well, if it was worth it to have more than one made at the same time, let me know.
Info sent via pm
No clue until I do a cost estimate. I have to have a harness in hand in order to do a cost estimate.
Info sent via pm
Sorry about the delay on this. Dokert sent you a follow up and will be sending the harness tomorrow morning via Priority.
